2 members (Hotrod Lincoln, baldeagle), 83 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#13645 02/14/2005 10:09 PM
Ok, I just got my Pennrite Steering box lube. Since this stuff is SO thick what is the best way to get it into the box? Also how much should it take?
#13646 02/15/2005 2:18 AM
A ziplock bag with a corner cut out makes a pretty good "grout bag", just like cake decorators and tile layers use. Just fill the bag, zip it up, and snip the corner and feed it into the fill hole.
Paint & Body Shop moderator
#13647 02/15/2005 2:46 AM
Did you warm it up some how?
#13648 02/15/2005 2:55 AM
Hi Thomas,
I just left the container in the sun for half an hour ( although it is the middle of summer in this neck of the woods) . You could put the container in a bucket of hot water. That should make it flow a bit better. I filled mine with a small funnel in the top of the steering box and a length of wire coathanger to agitate down the spout of the funnel. Worked fine.
Bob
#13649 02/15/2005 5:54 AM
You must have got the older style boxes. The new ones have a pop-up spout that you just pull-up on. Put the spout into the steering box and squeeze. Very easy to use. Sorry this doesn't help your situation, but I thought I let future buyers know that it's easier than it use to be.
Cecil.....
