6 members (MNSmith, jfjbjr, Southerntruck, Gray_Ghost, Otto Skorzeny, wilbur53), 163 guests, and 1 robot.
Topics128,080
Posts1,056,062
Members48,433
#13640 06/19/2003 4:52 PM
Junior Member
Junior Member
I found Stovebolt a few years ago when I owned a 52 pickup..enjoyed it alot. As happens with us guys, a little 52 hardtop caught my eye and I said fairwell to the truck.....now, I need help. The car has a 235, Powerglide....runs super...starts super....but its developed a glitch...and I'm not much of a mechanic. At an idle, when I press hard on the gas, it stalls...if I feather the throttle, it takes right off....runs great going down the road. Can anybody point me in the right direction? I'd appreciate it. dkoon@aol.com
#13641 06/19/2003 6:03 PM
Sounds like the accelerator pump in the carb.
Fred
52 3600
69 C-10
#13642 06/19/2003 7:37 PM
Junior Member
Junior Member
Thanks for the info Fred...I'll check it out
#13643 06/20/2003 3:19 AM
Olechev,
shut the engine down, take off the air cleaner or top and while looking into the carb, give the throttle a quick jab. If you don't see a stream of fuel come out, the acc. pump is the problem.
1951 1 Ton Completed
#13644 06/20/2003 11:45 AM
Check for vacuum leaks around the base of the carb and the manifold to head area. The carb may be running too rich as well.
