| | | Forums66 Topics128,089 Posts1,056,138 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13640 06/19/2003 4:52 PM | Joined: Jun 2003 Posts: 3 Junior Member | | Junior Member Joined: Jun 2003 Posts: 3 | I found Stovebolt a few years ago when I owned a 52 pickup..enjoyed it alot. As happens with us guys, a little 52 hardtop caught my eye and I said fairwell to the truck.....now, I need help. The car has a 235, Powerglide....runs super...starts super....but its developed a glitch...and I'm not much of a mechanic. At an idle, when I press hard on the gas, it stalls...if I feather the throttle, it takes right off....runs great going down the road. Can anybody point me in the right direction? I'd appreciate it. dkoon@aol.com | | |
#13641 06/19/2003 6:03 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like the accelerator pump in the carb.
Fred 52 3600 69 C-10
#13642 06/19/2003 7:37 PM | Joined: Jun 2003 Posts: 3 Junior Member | | Junior Member Joined: Jun 2003 Posts: 3 | Thanks for the info Fred...I'll check it out | | |
#13643 06/20/2003 3:19 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Olechev, shut the engine down, take off the air cleaner or top and while looking into the carb, give the throttle a quick jab. If you don't see a stream of fuel come out, the acc. pump is the problem. | | |
#13644 06/20/2003 11:45 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check for vacuum leaks around the base of the carb and the manifold to head area. The carb may be running too rich as well.
