7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | DId all Advance Design trucks come from the factory with a body tag in the door pillar? What year did they start tagging? Thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "DId all Advance Design [Advance-Design] trucks come from the factory with a body tag in the door pillar?" YES 1948 (1947 would be the same)1954 (1955-1st would be the same)"Location : stamped on plate attached to left front [driver's side] body hinge pillar." (between the hinges) It looks like this location was first used in Advance-Design trucks (1947 model onwards). | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | At least as far back as the early 1930's Chevrolet had a chassis/body/vehicle serial numbers (but they weren't always mounted on the door post) and engine serial numbers. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is GM/Chevrolet documentation regarding the locations of various "ID" tags/plates/information: 1936-1962. I'll look for pre-1936 ID information. Added later: 1935 is the first year that I can find GM stating the use of an Engine Serial Number and a Vehicle Serial Number (locations are not described).
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I found that same verbiage in the 1933 packet (didn't look any further)...as I recall it was pretty deep in the packet and only one line under the engine serial number info in the Specifications section. Mike B  | | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | Thank you everyone ... what an amazing source of information! | | |
