10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50), 49 guests, and 1 robot.
Topics128,074
Posts1,055,914
Members48,429
#1363910 06/08/2020 12:17 AM
DId all Advance Design trucks come from the factory with a body tag in the door pillar? What year did they start tagging?
Thanks!
cuzin #1363911 06/08/2020 12:27 AM
"DId all Advance Design [Advance-Design] trucks come from the factory with a body tag in the door pillar?"
YES
1948 (1947 would be the same)
1954 (1955-1st would be the same)
"Location : stamped on plate attached to left front [driver's side] body hinge pillar." (between the hinges)
It looks like this location was first used in Advance-Design trucks (1947 model onwards).
cuzin #1363938 06/08/2020 3:03 AM
At least as far back as the early 1930's Chevrolet had a chassis/body/vehicle serial numbers (but they weren't always mounted on the door post) and engine serial numbers.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
cuzin #1363962 06/08/2020 11:41 AM
Here is GM/Chevrolet documentation regarding the locations of various "ID" tags/plates/information: 1936-1962.
I'll look for pre-1936 ID information.
Added later:
1935 is the first year that I can find GM stating the use of an Engine Serial Number and a Vehicle Serial Number (locations are not described).
cuzin #1364027 06/08/2020 5:54 PM
I found that same verbiage in the 1933 packet (didn't look any further)...as I recall it was pretty deep in the packet and only one line under the engine serial number info in the Specifications section.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
cuzin #1364048 06/08/2020 8:59 PM
Thank you everyone ... what an amazing source of information!
