Plenty of
places to share.
5 members (cmayna , jay d , 2-Ton , 2 invisible),
44
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,009
Posts1,055,292
Members48,419
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
do you have to change the firewall to make a LS or small Chevy or Ford fit ?
woof359 Family 1952 3100 5 Window
You put a Ferd in it and we will hunt you down! Just sayin!ðŸ›
No, they can be installed without altering the firewall.
1951 Chevy Panel Truck
Not altered. Mind you, I planned for an electric fan and motor tight to the radiator.
With a smallblock Chevy, all I have ever had to do was bend the lower lip of the toeboard where the transmission hole is in the floor.
Thanks , I wasnt sure, do most make there own motor mounts and trans cross members ? no Ford, just throwing that out (-:
I know there's been plenty of small blocks installed without modifying the firewall. Anyhow, my buddy's dad used a bread pan to make a notch for the HEI distributor. I've heard of old valve covers used for the same purpose.
Crusing in the Passing Lane
Putting an electric fan on the engine side(sucking) is more efficient than in front. Might be best to move radiator fwd, like GMC, to get room. Ed
Way ahead of you. Only, I kept my radiator in the stock position. Like I said, I planned for this. The tape measure was my friend.
Camaro clip, so I made my own motor mounts and used a Chassis Engineering cross member that I mounted where I needed.
Evan
