0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | First I would like to say thanks for the add. I just purchased a 1952 GMC with a 228 and 3 speed. The truck is in good shape as with anything that is 68 years old it need some attention. The 228 looks stock has a 1 barrel Rochester carburetor that needs a kit or a replacement. My questions concerns the distributor. I would like to change the distributor over to a HEI type ignition. I have read where the distributor from a chevy 292 and other chevy distributor might fit with a few modification. I'm looking for some insight into these modification, which if any distributor to use? I have tried to do the search on Stovebolt and Google and don't seem to find the answer. If this is in the wrong section of the forum let me know.
Kosanow1
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | No. You can modify a Chevy 250/292 HEI Dizzy to work but it is best to find an original. The GMC truck is in itself a rare beast. However you can still find 228 & 248 industrial engines in older towns and country. I called an old Cracker friend that used a 228 for a saw mill but he said it was long ago sent to salvage. I think a 248 will fit. DOC
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | There are several sellers on EBay that have GM style HEI distributors for I-6 engines. They use the GM components so parts are readily available.ðŸ›
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | HEI distributors all work on 12v negative ground, if stock your GMC is 6v positive ground.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Lookat this. . They are good about phone calls .
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | Thanks Doc. My 228 is in good shape. Oil pressure and compression is good. Ive look at modiifing the oringanl. It feels like there may be a little slop in the shaft. I will no more when I take it out, as soon as I get time.
Kosanow1
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | Thanks Doc. My 228 is in good shape. Oil pressure and compression is good. Ive look at modiifing the oringanl. It feels like there may be a little slop in the shaft. I will no more when I take it out, as soon as I get time. HEI distributors all work on 12v negative ground, if stock your GMC is 6v positive ground. It's been converted to a 12 volt system
Kosanow1
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | There are several sellers on EBay that have GM style HEI distributors for I-6 engines. They use the GM components so parts are readily available.🛠Thanks I will look
Kosanow1
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | I will check them out thanks
Kosanow1
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | That is what I'm running. as stated needs 12 neg ground. Plug wires for a F**d 300 six with electronic ignition work great. Running A/C delco #7 platinum plugs.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | BC59, I found a shop that has quite a few AC non-resistor plugs (43 thru 47's), I bought a few sets for my 54-235. I heard that non-resistor plugs were out lawed due to all the cars in the late 50's and 60's because they interfered with NASA radio signals. Is this urban fable? Or are non resistor AC plugs still available? Ed
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | BC59, You mentioned that a 52 GMC had positive ground. My MGA has positve ground, can it be reversed? An old friend has a near mint 52 1/2 ton covered up in a barn since 1961. He is retired now and is inclined to sell. He hoped it would be a retirement project but, he and his wife bought a big motor home and plan on selling the farm. When it comes to the point where I start it should I disconnect the 6 volt battery in my 54 if the new battery in the GMC runs low? Or just leave my engine off an reverse jumper cable? Full of questions Ed
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | BC59, You mentioned that a 52 GMC had positive ground. My MGA has positve ground, can it be reversed? An old friend has a near mint 52 1/2 ton covered up in a barn since 1961. He is retired now and is inclined to sell. He hoped it would be a retirement project but, he and his wife bought a big motor home and plan on selling the farm. When it comes to the point where I start it should I disconnect the 6 volt battery in my 54 if the new battery in the GMC runs low? Or can I just reverse jumper and keep my engine off? Full of questions Ed
| | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | Changing from positive ground to negative ground will have some implications. You probably will have to get a new coil...one oriented differently. The positive ground coil will have the windings going in different directions in all likelihood. I've been also told the voltage regulator could need to be changed, but I'm not positive about that. Other than those two things, offhand I'm not certain the electrons will care much.
As for non-resistor plugs, you can use those only if you wear a hat made of tinfoil at all times. You should also sleep in it. Then the radio waves at NASA will be ok. Seriously, non-resistor plugs are still made. Last I looked, they were costly. As I recall, resistor plugs were simply a better match for radios at first (since at that time nearly all vehicles came with them) and later they were more friendly to ECUs and other vehicle electronics. You need to understand non-resistor plugs set up a very high degree of interference (electromagnetic interference) and will play havoc with other vehicle electronic devices.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | There is a Stovebolt Tech Tip on converting to 12 volt that also contains instructions for changing from positive ground to negative ground. Good read.ðŸ›
