Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, 3800GUY), 49 guests, and 2 robots.
Topics128,005
Posts1,055,266
Members48,418
#1363726 06/06/2020 8:07 PM
do you have to change the firewall to make a LS or small Chevy or Ford fit ?
woof359 Family 1952 3100 5 Window
woof359 #1363733 06/06/2020 8:42 PM
You put a Ferd in it and we will hunt you down! Just sayin!🛠
woof359 #1363741 06/06/2020 9:43 PM
No, they can be installed without altering the firewall.
1951 Chevy Panel Truck
woof359 #1363747 06/06/2020 10:50 PM
Not altered. Mind you, I planned for an electric fan and motor tight to the radiator.
woof359 #1363779 06/07/2020 2:46 AM
With a smallblock Chevy, all I have ever had to do was bend the lower lip of the toeboard where the transmission hole is in the floor.
woof359 #1363783 06/07/2020 3:09 AM
Thanks , I wasnt sure, do most make there own motor mounts and trans cross members ? no Ford, just throwing that out (-:
woof359 #1363788 06/07/2020 3:37 AM
I know there's been plenty of small blocks installed without modifying the firewall. Anyhow, my buddy's dad used a bread pan to make a notch for the HEI distributor. I've heard of old valve covers used for the same purpose.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
woof359 #1363810 06/07/2020 12:22 PM
Crusing in the Passing Lane
Putting an electric fan on the engine side(sucking) is more efficient than in front. Might be best to move radiator fwd, like GMC, to get room.
Ed
EdPruss #1363855 06/07/2020 6:27 PM
Ed
Way ahead of you. Only, I kept my radiator in the stock position. Like I said, I planned for this. The tape measure was my friend.
woof359 #1363856 06/07/2020 6:31 PM
Camaro clip, so I made my own motor mounts and used a Chassis Engineering cross member that I mounted where I needed.
woof359 #1363960 06/08/2020 11:29 AM
Evan
