2 members (Otto Skorzeny, DennisM), 91 guests, and 5 robots.
Topics128,026
Posts1,055,403
Members48,422
#1363643 06/05/2020 9:11 PM
one of the things I noticed first off when I bought my truck was you had to slam the doors to get them shut, slam them hardwould be a better description. After I noticed the strikers and latches were all new so I moved the striker out and out and out.......
I had to enlarge the adjustment holes until there was almost nothing left, now the doors with the windows down would shut OK but not great, when I told the wife too pull hard and firmly to her that must have ment wind up and give it every thing you got, Im surprised the glass didnt shatter
I had heard of these tin clips to go with the latchs but thought they were to good to be true, but I ordered a set anyway , installed them, and to my surprise they work. not perfect but with windows down the doors shut normally and windows up a lot more easier
woof359 Family 1952 3100 5 Window
woof359 #1363646 06/05/2020 9:35 PM
woof359 #1363648 06/05/2020 9:46 PM
I've had a similar problem with my '49 ever since I bought it. The doors have to be slammed to latch, despite trying all sorts of adjustments. I've come to the conclusion the door gasket rubber is either too thick, or too dense. It's fairly new, as the previous owner replaced all the rubber on/in the cab. Can anybody confirm or refute my conclusion?
Greg Brown
woof359 #1363657 06/05/2020 11:43 PM
I installed the SoftSeal door seals on my 49 and the doors would not shut. I ended up buying some "D" shaped seals that would collapse to 1/8" and now the doors shut fine. I also had trouble with my doors not staying latched. I bought the door latch clips and it fixed my doors as well. Great product.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
woof359 #1363669 06/06/2020 2:28 AM
Fox Offline
I built up my latch with my welder and then contoured it to a good radius. It made them act like new.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
woof359 #1363715 06/06/2020 7:09 PM
We often find ourselves looking for the easy fix with bad acting doors. Me included.
The truth of the matter with these doors is that you need to address all of the aspects of the door/latch/striker.
Number one would be to rebuild the the door hinges.
Number two would be to install the door without the door seals, with the striker removed.
Number three would be to make sure that the belt line of the door lines up with the belt line of the cab.
Doing those three things first will make your life much easier to tweak the door into an acceptable position to close properly.
