5 members (Ridgeback, Otto Skorzeny, 39Master85, 1955 1 Series, Hanks custodian), 80 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
If your on a dial-up or in Europe, you may not like this.
http://performancetrucks.net/forums/showthread.php?t=379097
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
You're doing some good work there. I don't usually pay much attention to Camaro's but enjoyed those pics too!
I've not heard of anyone swapping the new small block 427 into anything. Do you know of anyone playing with that motor? Looking at what you've posted elsewhere left me thinking you're the guy who would know.
One of my projects might be perfect with one of those...
Your thinking LS7?? There are a few guys on LS1tech doing it. Check out Johnb.. He has a Montecarlo SS that used to have an LS1 but is putting an LS7 in it.
Very interesting swap, let us know more as you proceed!
If the LS7 is motor in the new Z06 Corvette, then yes that's the one. I'm not seriously considering it right now, but it would be a good choice for a project about six or seven away from the top of my list.
Ok.. There are some up dated pics up.. I'm hoping 2 weeks till D-day..
cool.. should i yank the 6.6 out of my 05 and stick it in the 39?
Another quality post.
Real Trucks Rattle
looking good super73.
keep us posted.
Looking good. I was intending to use factory brackets to mount my S-10 Blazer fuel tank in my '53/S-10 Frame. You gave me the idea of just making my own brackets.
Also, I was looking at your motor mounts. Are they just solid steel? I didn't see any kind of rubber or plastic insulators between the mounts and the frame. Perhaps there are some I couldn't see or just overlooked? Otherwise you'd think the noise/vibration would be pretty intense.
There are some polly ends in there. Just can't see them due to the frame mounts being in front of them. They are on the bottom of the sqaure tube coming off the plate that is bolted to the motor.
Thought there probably were, they just weren't obvious.
Looks good. I put an LT-4 in my 57 . Works great. Plenty of power.
