4 members (Bill Hanlon, Shade Baby, Deegs53, Gray_Ghost), 159 guests, and 1 robot.
Topics128,192
Posts1,057,350
Members48,469
Ok. I parked the truck on concrete facing downhill the other day and it leaked gear oil from the rear end on the ground. I need a new pinion seal. I tried searching the forums for a source but came up empty. They recently closed the Napa by me.
It is a vacuum actuated 2 speed.
Thanks, Mike
There should be a number on the old seal that any parts place can cross reference.
Of course you'll be down till you can get the new seal.
3B Offline
Hy lightningtruck, rear axle parts/seals can be very tricky to find. The period you are asking about, many rear axles used a felt rather than a seal and the part numbers in the GM parts book reference the felts. After looking through most of my seal catalogues I think the seal may be National 411330N, the dimensions of the seal are O.D. 3.486", I.D. or shaft size 2.598" width 0.5", hope that helps.
Klhansen - i will tear into it and see what I find, thanks! Luckily I don't need truck for groceries.
3B - Thanks for info. When I take it apart I will measure and post dimensions.
Hopefully it is straight forward. I hope it is a real seal and not felt.
I guess they are Eaton axles? I have 2 '56 2spd rear axles here but from Fords. They look very similar.
Mike
I'd be surprised to hear your 5700 had a factory installed Eaton...more than likely it's a Chevrolet Corporate 15,000# rear.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Just park it uphill.
Ed
Sorry to bump up an old thread, but did you ever replace your seal? Was that the correct part number 3B listed? I have the same issue on my 56 6400
