0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | I want to replace the upper radiator hose on my 65 C60 with V8 350. Would a hose for a 65 C10 pickup be the same hose? I can find those easily. Thanks. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | The best way I know would to measure the id of the hose ends and the length of the hose. If it is a molded hose take it to your local parts store and see if they can match it up. If it has a 350 in it I Don't believe that is the original engine. Good luck Jim | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | 1969 was the first year for the 350 in the big trucks. Might see if one of the other V8 engines fits.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks for the responses. It had a 327 but I traded that engine for a 4 bolt main 350 a few years ago. I still have the same upper hose on there. It's getting dried out and I need to replace it soon. Yes I'll be taking it off and to the parts store. I was thinking this might be the same as the half tons but that engine might sit down farther from the radiator. I'll take the hose in and see what they can get me.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The parts stores in my area will let you go behind the counter to find a match if nothing shows up in the catalog.ðŸ›
| | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Yes here to. I have a flex hose that will be here in the morning. I will see how it fits. The radiator end measures 1 3/4" but the engine end is around 1 1/2". The old hose tightened down on the smaller end with no leaks. And this fitting on the engine end came off that 327 so it's what came on the truck. I hope this new hose fits. If not I might have to get a shorter hose and come up with an adapter. | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | You could put in a piece of metal (steel, copper, sst, etc.) and two short hoses. My '69 Tilt cab T50 came that way from the factory. The metal pipe can be any shape you want and any size on the ends. I would suggest a longish hose on at least one end to give it more movement. I don't have a good picture showing mine but I know it is original, the truck only had 4600 miles when I got it.
Mac :{)
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | On my Low Cab Forward I ended up getting a hose with the correct diameter and using part of it, cutting it to get to the radius section that fit.
| | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks for the ideas and info. I went back this morning after seeing that I needed to adapt 1 1/2" to 1 3/4". I could tell it wasn't going to clamp down tight like the old hose. After looking in a book they ordered a flex hose with 1 1/2" on one end and 1 3/4" on the other.
