3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
I have added a 350 to my 61 panel and need to install a new radiator, but which one. I have had the current one flushed but it still runs too hot. I assume the original is undersized. What are the recomendations from the board? I have looked at the Be Cool from Summit for $499. Any other suggestions.
Mac
I had these guys build me a custom radiator for a '61 Stepside I used to have. They made me a double bypass radiator. Keep a Hipo 454 nice and cool!!!! Seemed to remember it costing me about the same or a little less than the Walkers and the Summits, etc.
http://www.mattsonsradiator.com/
Don't have the catalog in front of me But I bought mine from Jegs. Part # 055551174
26X19 4 core all aluminum for $170 Have run it 1 yr and very happy with it.
Forgot to say I have a 62 and it fit quite well with only minor modifications.
Gazim
Couldnt find that part # but found one close. Does the universal radiator have side fins for mounting or did you need to use brackets?
Mac
I got mine from Summit (P/N SUM-380328) for $168. Required a little fab / mod of the existing radiator brackets, but it is in and cools the 230 all too well, and should handle the 350 that's coming with ease.
Daily Driver 63 C-10 LWB Fleetside
