0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1361787 05/24/2020 8:59 PM
wow have been trying to connct with big bolt for 2yrs...have read a lot but missed a lot of pictures cause i wasnt logged -in ...my son says im now reeady to go...so will give info from ill corn-belt wilderness ! good news is the belt is full of 6400 size trucks that are just too small to use. combine holds more than the truck ! theres for example alot of those widow maker wheels rusting away ...also some good tin ware...driveline...just stuff. My latest is 51 6400 235 good ole truck ! put a set of 2 under bearings in it in the truck now starts runs rides and drives put on about 4500 miles in coffee shop runs since 8-1-18. more later
fixite7 #1362308 05/27/2020 9:48 PM
have 2 vacuum boosters one on my48 dump one on my 51 6400 service book says to give these boosters 2 ozs bendix vacuum cylinder oil thru 1/8 th plug in booster canister one doesnt have a plug and where to get bendix vacuum cylinder oil ??
fixite7 #1362311 05/27/2020 9:51 PM
what does everyone do about this my 48 is probably getting hungry for this after 72 yrs !!1 more tomorrow
fixite7 #1362353 05/28/2020 1:07 AM
You do know you can go back and add to your previous post as long as no one has replied to it. No need to post every 3-4 minutes.
Try using capital letters a period or two and spacing. A lot of us are older and were taught how to properly compose a sentence. You are not texting on your phone. Thank you.
fixite7 #1362857 05/31/2020 3:09 AM
I was just researching this for my 1956 LCF.
I found most people recommend neets foot oil for leather or permatex hydraulic jack oil (formerly shock oil?).
I am going to put neets foot oil in mine this week.
My Hydrovac works fine but was not serviced for 9-10yrs.
Mike
fixite7 #1362906 05/31/2020 4:54 PM
Mike,thankyou for a reply on that oil question, my boosters work but suspect they are dry {the leather} ! That is a big leather cup ,i never thought about that shock oil will look into that !
