7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible), 52 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#1361479 05/22/2020 3:41 PM
I ran into an old friend who has stock (4.11) gears and became jealous that I am running 3.55 and wants to have a similar setup. Since I believe Patrick's is no longer, who do you guy recommend as a source?
cheers
Craig
ODSS Lawman
ODSS Lawman
Joe Mendola, aka Mothertrucker
Mother Trucker Trucks
520-570-4824
[email protected]
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet,
Thanks but the phone number you provided doesn't like me. I didn't realize that MT was still around. Email bounced back as well.
Craig
Send MT a PM, he's an active member, his handle is Mother.Trucker.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Or go straight to his Ebay ad, just search Chevrolet truck 3.55 and you will see his product.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Craig,
It you are looking for "parts kits" and cannot find some, let us know.
I am a firm believer/promoter of those parts kits.
Your installation will have:
- fewer leaks
- smoother/quieter running/operation
Kent,
I found MT on ebay with thanks.
Tim,
Thanks. While I wait to see if my friend wants to move forward, I'm now considering replacing my own 3.55 gears for mine have been recently found shredding some metal which is ending up in the oil. Got 13,000 miles on them and think it's probably best to simply replace the gears as well as both pinion bearings, etc. If there is a parts kit that you recommend, I'd be interested.
Regards
Craig
Craig
Here are some vendors who list the parts kits for sale:
Chevs of the 40s
Classic Parts - 1940-1950
Classic Parts 1951-1954
MT (Mother-Trucker) is the best source for the R&P gear set.
A 1954 31xx would need an earlier ring gear carrier.
Thanks Tim. I have sent MT a PM. Will keep you guys posted.
Craig
You mentioned in you posting about parts kits for rear end conversions to a 3.55.
Mother Trucker has the gear sets.
Can you tell me more about the kit?
Mike
By the way, is there anybody in The Tampa/St Petersburg area that has done this?
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
From The Filling Station
Kit includes: 2 Carrier Bearings, Pinion Bearing - Front, Pinion Bearing - Rear, 2 Wheel Bearings, 2 Rear Axle Seals, Torque Tube Bushing & Seal Assembly, Differential Carrier & Cover Gaskets, U-joint Gasket Kit, and Pinion Installation Tool. Does not include shim pack. Individual kit parts are also available. https://www.parts123.com/parts123/y...F0UNQ76238211414a~Z5Z5Z5~Z5Z5Z50000014a#
They sell kits with the Okie Bushing or without Okie Bushing
https://www.parts123.com/parts123/y...1F0UNQ76238211414a~Z5Z5Z5~Z5Z5Z50000014x
3.55:1 R&P Install instructions pdf (may take a couple seconds to load)
https://www.chevsofthe40s.com/images_media/instructions/INS_RPINSTALL%20TRK.pdf
Jim Carter has the Installation Kit, but they're currently on back order. PN HP166
I have been in touch with MT who does have the gear sets. For my case which is possibly replacing my current 3.55 set, he highly recommends I first tear everything apart to inspect and replace just the items which are showing possible issues. But since I just pulled a muscle in my back, I'll need to heal up a bit before ripping into the turd's backside.
Craig
Rebuild/Overhaul/3.55 Upgrade of the GM Torque Tube Driveline instructions
http://devestechnet.com/Home/DifferentialOverhaul
3.55:1 Ring-And-Pinion Swap - Make A Difference In Your Differential install photo album
https://www.hotrod.com/articles/1003clt-chevs-of-the-40s-3-55-1-ring-and-pinion-swap/
GM film strip 1952 Rear Axle Overhaul
https://www.flickr.com/photos/advance-design_parts_co/albums/72157639879860375
Thanks jorb and Tim for the links. Lots of good stuff to read before any of us go ripping into such a project.
Craig
