Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TooMany2count, Otto Skorzeny, Dakota Bob, 1 invisible), 110 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
#136207 11/30/2006 4:57 AM
Was checking spark on my 261 and found it's pretty weak, its been running a little rough lately. The points and wires/ plugs look pretty good so I thought I'd throw a coil at it. Is there anything to putting a higher output coil on it, or would I be wasting money and possibly burning up my points? Any ideas? :confused:
wrecker55,
What a great town you hail from! The points are only the 'trigger' for the secondary voltage. It is the secondary voltage that would be the hi-output value, so it wouldn't affect points.
Save your dough..unless you are running tons of compression and making it tough for a conventional coil to fire the plug, you are wasting money (IMHO).
You can check spark until the cows come home...the real test is out on the highway with
your number 13 mashed to the metal. How does it perform on the real world dyno?
Stuart-not-in-IA
Riding in the Passing Lane
A high output coil is not nessesary & would probably burn the points. Check the wires with an ohm meter. Resister wires should have no more than 10,000 ohms per foot. It should through a fat blue spark about 1/4 to 1/2 in. If you use it regularly I would install an elec. conv. kit. THen you may want to get the matching high output coil.
1972 Chevy c10 Cheyenne Super
#136210 12/02/2006 12:41 AM
I agree with Wrenchbender, why not try a Petronic's unit that will
adapt to your stock dist. & I would change the plug wires...
Try looking under the hood @ night (w/out light) & see if
you can see any plug wire "arching" to the block / frame etc.,
if so, you need plugs wires...
Are old trucks ever fixed, if so, whould there be a
"Stovebolt" page !
'53 GMC "Ranger"
Remember too that coils are "lazy" - they'll only produce the minimum output voltage necessary. Many a rodder has thrown money at a HO coil hoping to "rejuvenate" only to be disappointed when it fails to compensate for other worn, misadjusted, or broken parts.
Everything is different now...
