5 members (Jimmie D, treydrummer, DaveV, Phak1, dt235sd), 84 guests, and 5 robots.
Topics128,179
Posts1,057,163
Members48,465
Hello has anyone done a chassis swap like this?
I have a rusty 45 and can buy a complete driveline and chassis from a 57
Truck
Both are 1/2 ton
Thanks in advance!!
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
Measure the width of the front and rear axles, the 1957 will probably be wider.
Tommy
59 apache 1/2t
261 short stepside
Will not be a direct swap. Fabrication of mounts will be required. People put the Art Deco bodies on all sorts of late model and custom frames. It’s not easy but it is done.🛠
Thanks guys
I assumed the body mounts would be different
What do you think about harvesting the front and rear axles and driveline and installing on the Art Deco frame?
"Bad Guy"
"Big Guy"
Sir Searchalot
Sir Searchalot
Originally Posted by Suburban Lou
Thanks guys
This is WAY better. I have done restomods that way.
There is a good size list of things that you don't have to worry about with a axle swap as you do with a chassis/frame swap.
