1 members (Truckrolet),
156
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | Like the title says, I'm picking up a 67-72 2 wheel drive half ton truck and the RF just has a spindle. The truck is 200 miles away from me and 80 miles from anything that resembles a parts store. No hub/rotor or whatever the correct term is for drum brakes. My local parts store was no help. Also where the truck is located there is a 67-72 3/4 ton 2 wheel drive truck I can pull parts off of. Quickest, easiest thing I think would be the hub/rotor off of the 3/4 to make it roll on the trailer. Does anyone know if the bearings etc will fit to put a tire on to roll on the trailer? Next best plan is if anyone knows of another junkyard hub/rotor that will fit to roll it? Last not so good plan is skid it on the trailer as is with wood or old tires under it. Any other ideas to help get it to the house? I tried to do pics but no luck for me.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | IBenDcars Likely a difference between 67-70 C10 front spindles and 71-72 spindles as the earlier had drum brakes and later had disc brakes. Need to know year for gathering parts. I would consider a car dolly to haul it. Get front end on dolly, strap it down & head home. Very doubtful the 3/4 ton stuff will fit the C10. delky dave in WYO
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | LF has a drum brake, so 67 to 70 them. I don't have a car dolly. Hoping to get it on a regular trailer for the 200 miles home
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Skid or build a skate.,,,,,,,or a piece of plywood with a pallet or two attached to it might last long enough to get on trailer. Pulling it on backwards may be better, may drag better, don't know. May be better to take the other front wheel off and drag whole front suspension/frame on pallets. Pallets are free. Take a bunch with you. Old tires and pallets, what could be more fun
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | Thanks for the replies. The way it is sitting it will go on the trailer backwards. Definitely not fighting it to turn it around and then fight it up the ramp
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | As mentioned, the parts from the donor truck may or may not fit, but it certainly would not hurt to check. | | |
