3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1360610 05/16/2020 7:48 PM
On the drivers side latch for my '48 GMC with exterior pull down door handle. One thing leads to another. I purchased new door panels for 'Speedy', pulled the interior door handle and window crank and removed the old panel. I saw that the relay was adjusted improperly which explained why I could never lock the door. Easy enough to adjust and the lock now works correctly and smoothly.
However, now--for the first time--the outside door handle doesn't work! It moves just a little bit but feels as if the lock is engaged and doesn't move far enough to trip the latch. With the window rolled down I looked at the latch from the top and could see that the outside handle is attached to the latch and does turn a little bit before it stops. I tried it both locked and unlocked by the relay but it feels exactly the same either way.
I did a search but didn't find any specific information for this problem. A couple of you guys talked about taking a latch apart and rebuilding it but I'm mystified about how to do that. I
don't have a clue about how you did that! Looks like I'd be prying on things and hurting myself when the tool inevitably slips. I seem to remember seeing a good explanation of how the latches work, with pictures, but I'm unable to find it. There is a good tech tip article here on Stovebolt regarding the latches but I'm not getting the info I'm looking for.
Any ideas about a solution for this problem? Where can I look for more information?
Thanks, Jim
This may help.
https://www.flickr.com/photos/advance-design_parts_co/albums/72157641244124604
If you determine the latch is not workable I would suggest replacement with NOS only not a reproduction.
https://www.flickr.com/photos/advance-design_parts_co/15614660466/in/album-72157631868452754/
Thank you Brad, the first link you provide, '1948 Servicing Truck Cabs', is what I had seen but not remembered the source. I got a couple of parts latches from Jerry Rivers so maybe between them and the one on my truck I can figure a way to make one of them work. I'll start by re-adjusting the relay for the lock. It might be that I adjusted it too far and somehow that affected the function of the outside handle. I'm still hoping someone has fixed the same problem I'm experiencing and knows what I need to do!
