1 members (Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,080
Posts1,055,951
Members48,430
#1360581 05/16/2020 3:50 PM
I
I Offline
does anyone know what to set the valves at on my 236,is it the same as the 216,235,261 ???
WILLIAM A GOVE
Pardon my ignorance but exactly what is a 236? I don’t find a reference to it in the GM literature I have access to. No ID success with Google either. Year and model of your truck please.
H Online: Content
The "235" engine is actually 235.37 cubic inches. Like Ford and Chevy both did with the "302" V8, if you cheat about half a cubic inch you can use the higher displacement number.
Or is it a GMC?
William,
In each new thread, please post manufacturer/make, year, and model truck (if you know these)?
Insomniac
Insomniac
Or you could provide a reference to your earlier post...
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1355162/228.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Well, it must be a GMC 236. Not as common but still produced by GMC.
Professional Novice
Thanks Gord.
GMC engines bore & stroke on my site
http://victorylibrary.com/mopar/m-table-c.htm#GMC
I
I Offline
sorry its a 1946 gmc 1/2,but I,m pretty sure its not the original engine,
WILLIAM A GOVE
I
I Offline
it is a gmc
WILLIAM A GOVE
