0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1360581 05/16/2020 3:50 PM
I
I Offline
does anyone know what to set the valves at on my 236,is it the same as the 216,235,261 ???
WILLIAM A GOVE
Pardon my ignorance but exactly what is a 236? I don’t find a reference to it in the GM literature I have access to. No ID success with Google either. Year and model of your truck please.
The "235" engine is actually 235.37 cubic inches. Like Ford and Chevy both did with the "302" V8, if you cheat about half a cubic inch you can use the higher displacement number.
Or is it a GMC?
William,
In each new thread, please post manufacturer/make, year, and model truck (if you know these)?
Insomniac
Insomniac
Or you could provide a reference to your earlier post...
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1355162/228.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Well, it must be a GMC 236. Not as common but still produced by GMC.
Professional Novice
Thanks Gord.
GMC engines bore & stroke on my site
http://victorylibrary.com/mopar/m-table-c.htm#GMC
I
I Offline
sorry its a 1946 gmc 1/2,but I,m pretty sure its not the original engine,
WILLIAM A GOVE
I
I Offline
it is a gmc
WILLIAM A GOVE
