1 members (Phak1), 65 guests, and 1 robot.
Topics128,022
Posts1,055,361
Members48,420
#1359774 05/11/2020 2:44 PM
Jim C. Blue
Jim C. Blue
After much searching, I still don't know what the code means on my replacement engine.
I was told it is a 270.
Is shorter than the GMC engine it replaced.
Code is C225232
as seen in attached photo.
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
If the engine is shorter than you original GMC engine, it is probably a Chevrolet 216/235/261 engine.
If it is a Chevrolet engine, here are locations of ID codes (if USA and Canada codes are in same locations):
low-pressure engine ID codes
high-pressure engine ID codes
Find your codes and post them here. Someone should be able to "decode" them.
Is this in your 53 Canadian-built GMC 9700? Post more pictures of the engine, and look for the casting numbers on block and head. Canadian trucks had many differences from their USA cousins, especially engines. Actually they had a better model numbering system.
Professional Novice
3B Offline
Hy Alex Arrow, Please remember to tell us what year, make and size of truck (model designation) you are asking questions about. If Frank50 has it correct that you are asking about a Canadian 53 GMC 9700, that truck left the factory with a GMC full precision bearinged six cylinder engine, probably a 248 a 270 was an option. 248 engine serial numbers in Canada begin with the letter G sometimes a second letter before the numbers begin. The engine you showed us the serial number of is probably a Chevrolet, if you realize it is shorter than the engine that belongs there then it is most likely a Chevrolet engine. If you could post a larger picture of the engine showing the valve cover and the cylinder head we may be able to confirm the make of the engine, hope that helps.
I can't help with your engine ID, BUT, there is a brand new forum built specifically to help you ID your parts!
Another quality post.
Real Trucks Rattle
Rusty can you point me to that thread please? I also have a Canadian Stovebolt I need to identify. Cheers!
Jim C. Blue
Jim C. Blue
Well, it is a '53 GMC 9700 Canadian model, but the engine is not. It is not original in neither this one or the '50 it came from. No clue what it is actually from. This is likely why I am having trouble deciphering it, since I don't know what year it is or if it came from the US.
It will need more cleaning if the other numbers are needed.
Thanks for the replies.
Jim C. Blue
Jim C. Blue
Finally found two more numbers. One by the starter is a little difficult to read but appears to be 3837004. On top tho the head next to the intake manifold is 3836848. The only other thing I found was an M in a square between the pump and distributor.
Edit: The first number gets me results in a search. Claims to be a 235.
USA decoding (Canadian might be the same):
3836848 1956-1963 235 head
3837004 1955-1957 235 block
"M" = ?
Jim C. Blue
Jim C. Blue
Thanks!
3B Offline
Hy Guys, the "M" is the foundry identification.
If you take the valve cover off, he casting date for the head will be at the inside edge, driver side, about the middle. It will start with a letter, and the some numbers.
Mike
