Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Wickedbass, Wally / Montana, TexasA&M48Truck, FAST55, Chester2392, JW51, 68ironhead), 50 guests, and 4 robots.
Topics128,010
Posts1,055,298
Members48,419
#1359797 05/11/2020 5:30 PM
I had been awhile since I had started the engine, and when I did, it had a loud "thwack" near the top of the engine, passenger side.
Video:
I checked the pushrods, and couple had a slight wobble, but didnt get bent while idling. (checked with pushrod cover off, and holy crap what a mess)
After checking the lash adjustments twice, I decided to let it idle for 30 minutes, and the noise went away
video:
Any ideas what the noise was and why it went away?
Edit: 235 engine, hydraulic lifters, '848 head, '7004 block, Langdon HEI, plugs gapped to .050.
Joe W #1359798 05/11/2020 5:42 PM
Does the engine have solid or hydraulic lifters? It sounds like a hydraulic cam that somebody has adjusted like a solid lift engine. BTW, it's idling WAY too fast to run it with the valve cover off!
Joe W #1359803 05/11/2020 6:02 PM
Its adjusted like a hydraulic lifter, I went 1/2 turn instead of 1.5 turns. Its idling around 700, I'll lower that down to 500.
Joe W #1359818 05/11/2020 7:14 PM
It's not uncommon for a hydraulic lifter that sits for awhile with the valve held open to leak down all the way. 235's are notorious for lifters collapsing and taking a long time to pump back up, especially with the replacement lifters that are available now. I'm working on a project to sleeve down the lifter bores a little and run hydraulic lifters for MOPAR/Ford/AMC engines instead of the unreliable Chevy stovebolt hydraulics.
