1 members (Steelonsteel),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Hey, I got a'49 3600 and I want to basically get the truck as low as I can (and still be usable) but without having to spend a lot of money on say a whole new camero/ nova or Mustang II front end. I'm trying to do a lot of the work myself and don't know if I'm capable enough to swap in a new front clip. I've seen the 3" drop front axle but can some of you guys tell me if there will be any clearance probs that have used it. And maybe a set of drop spindles. I'm not too worried about the rear, I know it's much easier. I think a spring flip on the front would cause a lot of clearance problems. Basically I want to know what works the best without causing a lot of clearance issues and still be inexpensive. Thanks. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
This is a 3600 right? A 3/4-ton with 8-lug hubs.
Most the suspension mod parts available are for a 1/2-ton so you may have trouble finding pieces designed for this truck.
I've seen a front axle flipped up on top the springs. It was done on a truck that I doubt was ever driven and the clearence was basically zero. I think I posted a picture here when I saw it as an example of what not to do.
Since you are lowering the truck I doubt you care about the 3/4-ton rating. You might look at buying a dropped 1/2-ton axle and switching to 1/2-ton front spindles and brakes. This approach opens the door to disk brake swap kits which are not available for your current set up.
Another possibility is to have your existing axle dropped. Basically you send it to someone who heats the ends of the axle and stretches the drop longer. I've even heard of people doing it themselves, but I think you'd want to know your stuff before you tried it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
