Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Joe W, baldeagle, Hotrod Lincoln), 53 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#1350267 03/16/2020 10:48 PM
Now that the price has almost doubled from when I started looking a couple years ago, finally pulled the trigger on a lift. Love it.
Allen
1974 Stingray Corvette
Allen Lane #1350326 03/17/2020 3:23 AM
So, what did you get?
Post some Pictures...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Allen Lane #1350411 03/17/2020 10:00 PM
After much analysis paralysis, I went with the Advantage 9K XTL lift. It doesn't have the cert's that Bendpack and a few others do, but after putting my hands on them, it was much beefier, had the secondary latch, didn't need air to clear latches, and the complete package and support won the day. I've been stalking them at our local Mecum auction for the last several years. My shop layout isn't final, so I needed to be able to move it around as my plan becomes clearer. Hope the pics work.
Allen
Allen Lane #1350438 03/18/2020 12:39 AM
How tall is the ceiling in your shop?
1937 GC
Allen Lane #1350448 03/18/2020 1:15 AM
Not tall enough. 10' ceilings, wish I had 14' and I could get two stovebolts on/under it.
Allen
Allen Lane #1350449 03/18/2020 1:25 AM
I have been investigating a lift. I only have 12: walls and don't know if that would be enough headroom. Thanks for the info, will keep looking. Bill
1937 GC
Allen Lane #1350456 03/18/2020 1:49 AM
Here’s mine. Very affordable. I have 12’ walls. Fits very nicely. I hired a pro to install it and he gave it a thumbs up. Derek Weaver has two locations. Texas and NC.
MY LIFT
Allen Lane #1350465 03/18/2020 2:26 AM
Very nice lift....and truck
1937 GC
Allen Lane #1350467 03/18/2020 2:35 AM
I like the LED lights, might have to do mine that way...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Allen Lane #1350809 03/20/2020 2:00 PM
Installed a 2 post lift on the unheated 15' wall side of my barn last summer. It has become an invaluable tool!!! Lot easier standing up working on vehicles versus laying on your back. Should have done this 40 years ago.
Rick
1939 Chevrolet Stake Truck
Allen Lane #1350814 03/20/2020 2:24 PM
I purchased my 4 poster a few years ago. I truly believe that had I had one 25 years ago when we moved here to the ranch I would have gotten back into the classic vehicle hobby much sooner. I have accomplished more in the last 4 years than I did in the previous 20 all put together.
Allen Lane #1350820 03/20/2020 3:30 PM
Man, those really look like they would be nice. I have 11' ceiling so not sure if it would work for me though.
Dennis
40 Chevy 1/2 ton
DennisM #1350871 03/20/2020 9:20 PM
If you're really short, that would work. wink
I'd love to have a lift. As I get older, working underneath anything gets harder. frown
Allen Lane #1352506 03/31/2020 1:54 AM
Thats the same lift that I have, I've had it about 4 years. I like the LEDs, got a link for them?
They came with the lift as an option. I would just contact Advantage. I looked around to try and DIY it, and the best option I saw on YouTube with video.....but he ended up spending about the same plus a day to put it all together. They are nice and bright and out of the way. Highly recommend them.
Allen
Allen Lane #1358945 05/06/2020 4:42 PM
I have 14' ceilings and a 2 post 12K# lift. It's one of those "how did I live without it" tools. Add a couple of lifting straps and unload pallets out of the back of the truck. I even use it to clean my mower deck. I have changed engines with it.
Mike B #1359010 05/07/2020 1:22 AM
MikeB, What lift is that you have? I have 11"6 ceiling and have been looking for a 2 or 4 post lift with the short posts for clearances. Assuming that your lift is at least 9k#. Do you happen to know the depth of the floor you have that on? One of the problems I have run into is I'm on a residential floor, only 4.5 in. thick. Many heavier capacity lifts call for 6" minimums.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
bigedpa #1359043 05/07/2020 4:53 AM
My lift is a New Grand International rated at 12,000 pounds. It came out of a working Midas Muffler shop that was relocation 2-blocks away and the day before the big move they sold all 6 of their lifts in 15 minutes...mine was set up for alignment work with turntables which I completely removed and re-decked.
The foot print of the posts (out to out) is 11'3" wide x 15'4" long with 16'8" runners and 5' ramps. The runners extend past the posts and the ramps hang off the back for a total length of 21'8". I have 6+ inches of concrete under the lift. The top of the cylinder is 8' above the floor. Your 14' ceiling should be just fine...mines 16' and there's tons of room above the wrecker.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Allen Lane #1359192 05/08/2020 3:41 AM
My 12k 2 post lift is on 4" concrete. I build factories for a living. My pads are 14" X 14". That's 392 sq in. That's less pounds per square inch than when your car is parked on the floor even with the weight of the lift. The crappiest residential concrete must be a minimum of 3500 psi by code. That's usually used for sidewalks. Yours is most likely 4000 psi or more. The most important thing on a 2 post is the anchors because they can be loaded out of balance. We use large diameter Tapcons with epoxy to anchor our machines. JMHO.
Allen Lane #1359239 05/08/2020 4:17 PM
Former Workshop Owner
Quote
So, has anyone ever secured a 2 post lift to the ceiling for added stability? I have pex tubing in my floor for heat. My concrete is only 4.5 inches thick. I don't want to drill into a line.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Allen Lane #1359256 05/08/2020 6:17 PM
We need one of our resident structural engineers to chime in, but having tubing in the floor would weaken it in my mind...what's the grid spacing on the PEX? Is there any rebar, fiberglass strands or wire mesh in the concrete...that all weighs into the mix as well.
Do you know where the PEX is in the floor and will you be able to center the legs between two parallel runs of the tubing?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Allen Lane #1359261 05/08/2020 6:41 PM
Moderator
Moderator
2 Offline
A couple thoughts John. What about using cables to run each way to the wall?
Or cables angled down and anchored to the concrete like utility poles. They would be in the way though.
Give us some more info about how your shop is framed up and we will talk it out.
Don
Edit: A great Machinist thinks outside of the box!
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Allen Lane #1359309 05/09/2020 1:22 AM
Full block foundation on frost footings with 14' side walls. Double wire mesh, the pex is sandwiched in between. I do not know exactly where the pex is. I have 4 zones and just guessing that it's about 12" on center. A lift, let alone a 2 post wasn't even a consideration when I built it back in 05-06. Still not sure that I want one, but if I was doing it again I would surely plan for it.
I'm not concerned about the floor holding the weight, as I could always add a steel plate and double or triple the foot print. I just have always wondered about the possibility of securing one to the ceiling for stability. Unless the vehicle was extremely out off center I don't think it would take much to stabilize the load. I really just wondered if anyone has ever done it.
Steel cables angled down would work (interesting idea) but I think that they would be in the way.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Allen Lane #1359313 05/09/2020 1:50 AM
I'm not a structural engineer, but I don't think the presence of the PEX will significantly weaken the slab.
If you want to find the PEX, let the slab go completely cold, then crank up the heat and use an infrared thermometer or an infrared camera (I have a cool one from FLIR that plugs onto an iPhone). You can tell where the slab is by the warmer spots in the slab. It won't be exact, but you should be able to see the spacing, and get your anchor bolts between the tubing.
Allen Lane #1359319 05/09/2020 2:59 AM
My lift is 16' tall and I have 14' ceilings I boxed it in between 2 trusses. It's not holding it in place I just felt better framing it in. Some of the new stud finders can locate plastic water lines. If your floor is built to the international residential code it will have 6" X 6" welded wire mesh in it. Keep in mind building codes are minimum requirements. I am a licensed structural commercial contractor but I have no idea how your floor was built. There are ways to have it tested.
Allen Lane #1359321 05/09/2020 3:05 AM
Would one of those Walabots work to find the pex?
They make free standing 4-post lifts that can be rolled around when not in use.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Allen Lane #1359336 05/09/2020 11:50 AM
My lift story.
LINK HERE
Allen Lane #1359429 05/09/2020 11:16 PM
I think the walabot will. I don't have one since I just watch these days. The problem with securing to the ceiling is that your garage was most likely not designed for that kind of lateral load. You could run some 2 X 6's at 45 deg. to your trusses in both directions and put osb on the walls for shear but where and how much would be a question for an engineer. I have 4" concrete with one layer of 6X6ww and I have had my 12500# ambulance on it for extended periods of time and just unloaded a 2000# lathe using just 2 arms. You may be over thinking this. One 3/4" tapcon with epoxy has tons of holding power
Allen Lane #1360407 05/15/2020 1:48 PM
I have found that my 4 post lift, which I have had since 2013 is the best tool in the garage, the only regret is I didn't get it 20 years ago. Its first job after assembling it in the garage was to lift the existing roof (trusses,sheeting and roofing) off the top of the wall plates and install some 4' pony walls above the double top plates , then lower it back down, This gave me 12-1/2' ceiling height. I really like your lighting setup.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Allen Lane #1362907 05/31/2020 5:08 PM
I agree, every time I use my 4 post lift I kick myself for not having one sooner.
If I had known I would have put one outside on 4 small pads.
Mine is backyard buddy style. Does not anchor to floor. You can move it if needed.
I also have an 11000lb 2 post. Instructions say 4in. Minimum 3500psi with welded wire minimum. Just some more info for you.
I was really wondering about the lighting on the one 4 post lift.
I have experimented putting single tube florescent bulbs in that location and they blind me without really lighting the bottom of the vehicle.
Do you have this problem? I am thinking of led strips with aluminum shields?
Mike
Moderated by  MNSmith
