3 members (klhansen, Danielbolt, 1 invisible), 156 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Posted picture of the problem spot. This is the handle mount for a C20 4 speed with propeller band brake. I just need to know how to remove what appears to be a clip that holds the brake handle in place. This is the pivot point on the body of the 4 speed.
Also, does anyone know of a spot on the internet with good parts available for this type of brake unit? Seems they used them for a long time. I want to replace the band as long as I am tearing it apart. thanks
1960 C20 Apache Step Side Long Bed
"Swamp Thing" restoration
Story starts in 60-66 trucks
Put a screw driver under the little raised tab on the clip and gently bend it up far enough to slide the back half of the clip off the shaft...try real hard not to over-bend and break the clip as I don't think you can get that style anymore.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Should be someone in the Portland area that can recline it.
BC
1960 C60 pasture art
It worked, just seemed to simple. There was a spring behind a bushing. Pushed in the bushing and was able to remove the clip in a short time. Looks like it will go back to it's old shape and be used again. thanks
