1 members (dt235sd), 307 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
Can somebody confirm to me the centerline horizontal hole dimension of the 2 heater hose holes in the right hand side of the firewall. I rebuilt that corner of the cab. Still have the innermost hole to reference off of but need to put in the outermost hole.
The actual heater port centerline dimension is 1-13/16" but laying in my mangled old cab sheet metal with that needed hole the spacing seems to be wider than that. 1951 Chevy 1/2 ton.
Thank you in advance!
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
2-1/2" center to center from the inboard hole. 4-3/4 below the lower hood hinge bolt hole. The outboard hole is slightly (maybe 1/8") above the inboard hole.
From one M.E. to another..Thank you Kevin!
Mike
Mike
1971 Chevelle
You're very welcome. We look to be at about the same point in restoration.
Glad I could help you out.
