2 members (Hotrod Lincoln, Jimmie D), 55 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Page 2 of 2 1 2
Ok folks, I just deleted two posts that had nothing to do with tools. Please stay on topic.
Nice, Brad
Is the "cooler" in the bed (3rd photo) bolted/attached to anything (to keep it from sliding around)?
Yes it has a bolt through the center and padded feet to keep it in place. Removes quick if I need the room. The cooler is a cut down (not by me) 1939 Westinghouse Jr. Ice.
thumbs_up
Brad
you give me a good idea for storing tools outside the cab
I’ve got an old yellow us jerricans that I will transformed into a tools box fixed at the same place you do .it’s a lost place
More safe
Alain
I have looked but I have not found where the jack is stored in my 54-3100, under the seat is my best guess. The bed has a special factory slot for the handle, anyone know? Doc
Depending on the 1954 3000 model, in an under-seat/underfloor compartment.
I'd put it in a heavy canvas bag.
Supposedly a 30" x 19" x 6" tool box was under the seat was standard equipment.
Has anyone seen one?
Tim,
I may be wrong but I recall Chevrolet literature referring to the space under the seat cushion as a "tool box". I am not aware of an actual box or something extra to store tools. I keep the jack, handle and fire extinguisher under the seat in that space. This is all sitting on an old towel to keep things from rattling. I like your heavy canvas bag idea.
Kent
P.S. I found it. Page 21 of my 1951 Truck Data Book Model 3104 Tool Box--Under Seat, 50" x 19 1/2" x 6"
It is listed for all the models with a cab as standard equipment.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
You beat me to it, Dad
As you know, under seat storage spaces/areas are different sizes in several different series/sized trucks.
Crusing in the Passing Lane
My '54 GMC has a perch for the jack behind the driver's left elbow in the corner behind the seat. Space for tools under the seat.
Ed
My ‘57 3200 has a spot behind drivers seat too in corner of cab. I just use my truck as a daily driver locally, never more than 20 miles away, so I don’t carry a spare or jack. Just keep my wife on speed dial. I plan to make a bracket to keep a fire extinguisher in that spot.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
DES57,
If you are referring to a lower rear cab corner, be sure the "weep hole" (drain "eyelet"/opening") is clear/open.
That location is a convenient location. Easily accessible, when something is needed.
Page 2 of 2 1 2
