6 members (WICruiser, Gdads51, Jay R, 55shaker, Ponchogl, DadsFirstPickup), 129 guests, and 1 robot.
Topics128,054
Posts1,055,782
#1358079 05/01/2020 2:10 PM
Bolters
Last week a friend made my engine (235ci 54 1/2T)drain and change oil whith 20w50.That’s what Many people use in france for the américain old lady
What do you think about?
Best regards
It's a little heavier then I would use, but if that's what you have, that's what you run. It's likely very good oil and has the additives your older engine needs, what is weather like where the truck is? If its really cold, your oil pump will be working pretty hard. Hotter temps, no problem.
Stay safe,
Joe
I agree, too heavy.
I use 10W 30 so that's what I suggest. A 20W 50 seems a bit viscous and I would have guessed it was for a big diesel truck but I see it's for "essence" too.
I’m on the west coast and winter are Not very cold ,frost are rare
More often We have between 6 and 30 degrés C
It’s ok?
Alain
That would be 43-86 degrees F, not a brutal range. My 1948 owner's manual advises straight weights 20W or 20 for that temperature range but they probably didn't have 10W 30 or 20W 50 then. 50 at the hot end is half-way to gear lube for the rear end. Too thick for me.
You should post some pictures with what has to be great scenery.
Ex Hall Monitor
Ex Hall Monitor
Another oil debate. I use 15w40 in my 38 and 53. I'm not sure 20w50 would necessarily be too thick in the summer. We need to remember that oil thins as it warms up so the 50 hot may be thinner than the 20 cold. I don't think I'd use it in the winter. Having said that I drive both of my vehicles year around and 40 isn't that much thinner than 50. ohwell
For some reason I really enjoy the discussions about oil. Today I just bought a jug of 15-40 as I'm changing oil tomorrow morning. My first experience driving the truck a few years ago, I put in 10-30 but found the oil pressure was too low.
