0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1357925 04/30/2020 3:47 PM
Hi folks.
My progress restoring my 1958 3200 Fleetside has been stalled for a few years. Now I'm finally making progress. Cab is on my rebuilt frame. Working on installation of electrical wiring and associated equipment.
I need some help finding the right size battery. All 'battery selector' charts seem to suggest a group 24 or 34 battery. Both are 10 3/4" wide, but my battery holder measures about 10"W, 7"D and up to about 9" T. So it looks like a 24/34 is too wide.
Based on dimensions, a group 35 would be a better fit.
So what size batteries normally fit my TF truck?
John.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20
I typically just measure my battery box, find a battery that fits AND has enough CCA's to meet or exceed the amount required by your equipment. I also buy the cheapest acceptable battery I can find if the project is not being used on a regular basis. I usually keep it on a battery tender as well.
Another quality post.
Real Trucks Rattle
My battery box in my 55.2 3100 is just shy of 11 inches by 8 inches.
Brian
1955.2 3100 Truck
It sounds like you've got a battery box for a Group 1 6 volt.
For longevity, an Optima is a great battery but expensive. I had one in my 54 for 13 years but it was getting weak and I was going to KC and I bought an Auto Zone brand for a little less money. It also an AGM.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks for the replies.
For the record Hotrod Lincoln, my 58 was built as a 12 Volt system.
Looks like my bracket is sized for a Group 35 battery. Definitely not 11x8 like in 55 Shaker's 55-2 3100.
I'll see what I can find in an AGM battery.
John.
Something to think about when sizing a battery maybe; the po of my truck put in a new battery for me ( a 24F) it has worked fine, and fits in the battery shelf, but the hold down bracket will not go over the top due to the side pieces that the carrying handle fit through. When I need to replace it, I’ll take the hold down bracket with me to try to find one that it will fit over. I probably could take a razor blade and shave off the offending parts, but then I would loose that convenient handle. As long as I don’t go inverted, it should stay in place anyway.
Lee.
1956 Chevy 3200, 235 w/3 speed
I think the original battery was a 2SMR53 Delco tar-top battery:
10.25" x 6.75" x 9"
LeeD, strap your battery down until you get it figured out!
Real Trucks Rattle
