3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#1357809 04/29/2020 8:54 PM
I have a standard bore 1948 235 . Cast iron pistons .
Can I use standard 1955 > 235 alloy pistons (is the gudgeon height the same) ?
Yes, the wrist pin height and diameter is the same for both pistons. A 216 can be bored out .0625" and use 235 pistons, also. It becomes a 224 cubic inch when that is done.
Thanks Jerry , just looking to see if I can make the 235 dipper a smoother runner .
The lighter weight pistons put a lot less stress on the Babbit bearings, and the engine accelerates quicker since those heavy iron pistons don't have to change directions several times a second. At 2000 RPM, they're starting and stopping 33 times a second!
Dusty #1357833 04/29/2020 11:18 PM
That was my thinking Jerry , although this engine is new , I think swapping the original cast iron pistons for alloy has to be of benefit to the engine life , not that I'm ever going to wear it out (it's taken me over 23 yrs to do just 80,000 miles in this truck . I'm only doing the engine change due to massive cracked block in the original 216 .
