7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have a standard bore 1948 235 . Cast iron pistons .
Can I use standard 1955 > 235 alloy pistons (is the gudgeon height the same) ? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Yes, the wrist pin height and diameter is the same for both pistons. A 216 can be bored out .0625" and use 235 pistons, also. It becomes a 224 cubic inch when that is done. Jerry
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks Jerry , just looking to see if I can make the 235 dipper a smoother runner . | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The lighter weight pistons put a lot less stress on the Babbit bearings, and the engine accelerates quicker since those heavy iron pistons don't have to change directions several times a second. At 2000 RPM, they're starting and stopping 33 times a second! Jerry
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | That was my thinking Jerry , although this engine is new , I think swapping the original cast iron pistons for alloy has to be of benefit to the engine life , not that I'm ever going to wear it out (it's taken me over 23 yrs to do just 80,000 miles in this truck . I'm only doing the engine change due to massive cracked block in the original 216 . | | |
