1 members (1 invisible), 103 guests, and 0 robots.
Topics128,117
Posts1,056,298
Members48,439
#1357656 04/28/2020 11:05 PM
1951 chevy 3100
1951 chevy 3100
Can someone tell me the torque lbs to tighten down the cap on the differential. 1951 chevy 3100 and is there a suggested pattern?
This is the section of the 48-51 Truck Shop Manual that covers the 1/2-ton differential. Hopefully you can get the info you need from it.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0402.htm
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0448.htm Torque specs.
From there you can navigate to all areas of the manual. Good luck.
Professional Novice
1951 chevy 3100
1951 chevy 3100
I looked at that but was not clear to me .
Page 4-9
Item 5. Tighten bearing cap bolts to 115-135 ft. lbs. Recheck backlash and install both adjusting nut locks.
Moderator, Electrical Bay
J Online: Content
I think possibly he means the rear cover plate and for that there are no torque specs I've ever seen.
~ Jon
Jon, you may be right. Cap to me meant bearing caps. In that case, just find a generic torque spec for the bolt size (5/16" NC?), or use the old tried and true "Torque 'em down till they break and back off 1/2 turn." wink As far as pattern, probably not critical, but a "star" would be appropriate after snugging all the bolts finger tight.
I usually don't bother with the torque wrench on stuff like cover bolts, just grab the socket wrench close to the business end and twist them snug with one hand.
1951 chevy 3100
1951 chevy 3100
thanks guys
