2 members (Otto Skorzeny, VicZ),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,059 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 4 New Guy | | New Guy Joined: Nov 2019 Posts: 4 | I just bought a Weiand 9240P water pump but it does not fit around the timing cover?? It does not seem like the timing cover can be any smaller. The mounting area of the water pump is thicker than the old one I pulled off. Does this issue come up often? Can I grind off a little bit of the water pump? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | It's always helpful to tell us what engine you're working on- - - - -we're not very good at reading minds. I've never heard of Weiand making anything but race engine stuff, so it's pretty obvious you're not working on a stovebolt six, right? Is there some reason for not using an original equipment type part? Jerry
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Can I grind off a little bit of the water pump? No, a water pump is not a "grind to fit" part. Sounds like you're working on a SBC. Do you also have an aftermarket timing cover? Also don't forget SBC water pumps come in a long snout and short snout versions. SimS | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | And, depending on year/belt type, different rotations. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I've read some posts on other forums where the Weiand water pumps have some clearance issues. Most opt for a little clearancing with a die grinder. | | |
