4 members (ShopRag, Youngin' Tut 59, klhansen, 1 invisible), 104 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
Moderated
Moderated
All -
I have a new-to-me 1951 Chevy 3100 half ton truck. I want to check the transmission & rear axle fluid levels. I think I've identified the proper plugs in each, but after a lifetime of doing, then asking advice, with mixed results, I thought I'd ask advice first.
I believe this is the fill plug for the transmission. On the right side of the tranny.
Transmission Plug
I believe this is the fill plug for the rear axle.
Rear Axle Plug
The rear plate of the differential does not have a plug in it.
Differential Cover
Sooooooooooooooooooo, I'd appreciate confirmation or information to the contrary. many thanks.
Cheers,
dave
You are correct! the diff cover doesn't need a fill plug, because, the rear axle fill plug does the job.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
