| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I have a 53 235 engine main bolts needed. I have a couple of main bolt broken. When I look for new bolts they list 54 thru 62 . So will they work on 53 235 main bolts? | | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | I have a set of main bearing caps and bolts out of a '56 235. There are four 3" bolts with 9/16"-12 threads, and Six 2 1/2" bolts with 1/2"-13 threads. If these are the same as yours the 54 through 62 bolts should work. | | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | Thanks bolts are supposed to be here at the end of this week. | | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | I just re-measured the bolts and there are four, three inch 9/16-12 bolts, four 2 3/8" 1/2-13 bolts and two 2 1/2" 9/16-12 bolts. Sorry for the confusion and I hope this is what you need. Bumpa49 | | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I got the new ARP bolts. But I found some cracks in the rear main in the block. So the block is chunk. I think I will find a 250 engine. Could I possibly be able to use the ARP bolts on a 250 engine? | | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | No, there are a different number of bolts, different size, and 7 main bearing instead of 4 on the 250. You're opening up a huge can of worms if you try to go to the later model engine- - - -nothing will fit. The bell housing bolt pattern is different, and so are the motor mounts. Where are the cracks you're concerned about? Jerry
| | | | | Joined: Apr 2016 Posts: 1,049 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,049 | If you plan on going to all that trouble why not a 292?
| | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I found a 292 I will be picking the 292 tomorrow. The cracks were about a half inch long. The cracks was on the side of the block were the oil pump mounts to. Another crack was on back of the engine block. Were the rear main bolts. | | |
