3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#135675 10/14/2006 2:47 AM
Junior Member
Junior Member
I know this has been discussed many times but
I have tried putting the axle on top of the
leaf springs but to many clarance problems.
only had about 1" clearance from top of frame.
tonight I tried swicthing the leaf springs by
reveasing the order they are when stock. plus took out three leafs. put it back together and
I think my clearance was worse. I want the truck
to have a very low stance!! besides changing the
front end to a clip Is there any thing else I can
try. I love this hobby but two kids means a low
buget!! please any help would be great,
#135676 10/15/2006 4:08 AM
Junior Member
Junior Member
I went with mono springs and low profile tires on my 53 GMC and it lowered 3 1/2" to 4" from stock. Rides great and no clearance problems. Also added sway bar.
#135677 10/15/2006 7:37 AM
48speedshop,
Could you put your feelers out for a dropped front axle. This would probably be the most cost effective way to lower the front end.
I would consider the attempts describes above as unsafe.
Stuart
#135678 10/17/2006 6:54 PM
48 SpeedShop,
I had my straight axle dropped 4 inches by Dave at www.roadsters.com. I think it cost me about $300 at the time. It sits nice and low in the front and it doesn't have the clearance issues that you encountered with flipping the axle on top of the springs. The one gotcha is you need to heat and bend the steering arms down so that the tie rod will clear the leafs springs. You will also need to shorten the tierod because the dropped axle will move the tires inward slightly(no clearance issues though)
Here's a shot of how my truck sits:
http://i24.photobucket.com/albums/c13/rsg2506/dcp_0007.jpg
-Rich
#135679 10/18/2006 10:33 PM
put all the leaf springs back like stock and remove the stock rubber cushion put one like a 3/4 ton that mounts on the frame that should increase your axle to frame clearance
1949 SUBURBAN
#135680 10/19/2006 5:32 PM
I have patricks front and lowering stuff on my 52, works well for me..
here is their link
click here
Redryder pix
My Hotrod
#135681 10/26/2006 1:52 AM
Junior Member
Junior Member
I had mine dropped by loudpedal on the HAMB, also classic performance products sells a drop axle
#135682 11/18/2006 11:32 AM
Just an idea, but what would happen if you pulled all the leaves except 1 or 2 and added an air over leaf type setup? That should allow you to drop it down low for shows and air up for driving.
Then again, I have no idea whether it would allow enough room to actually steer.
#135683 11/20/2006 9:29 PM
I LIKE THE DROPPED AXLE APPROACH. I WOULD RETHER
USE A SET OF DROPPED STEERING ARMS IF THEY COULD
BE FOUND. GOOD LUCK AND SEND PICTURES,
