4 members (DaveV, 55shaker, jmoore, Hambone), 90 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#135641 10/10/2006 11:00 PM
Hi All,
I have a 250 chevy engine that has powered a sawmill for years that needs an overhaul. A friend can bore it for me but he doesn't have a torque plate for the six. He would do it for free and he says not having a torque plate would not matter for the six. Does it matter? Getting it bored by the local shop is a little over a hundred bucks and I wouldn' mind spending it if it matters, but I can always use a hundred bucks if it doesn't. For example, I could buy some rotors for a brake conversion... Let me know what you think about the torque plate.
Thanks! Rick in VA
#135642 10/11/2006 12:01 AM
If you are going to do something drastic like deck the block and shave the heads to increase compression for some sort of high performance (on a 250?) application then I would say yes. If you are just going to rebuild it and put it back in the sawmill I doubt that boring the engine with or without torque plates installed would make much difference one way or the other. Just my .02...
Daily Driver 63 C-10 LWB Fleetside
#135643 10/11/2006 1:26 AM
Thanks Texmo. This is what my friend who is willing to do the boring says. Thats two votes saying don't worry.
Rick In VA
#135644 10/11/2006 10:20 PM
Riding in the Passing Lane
I vote don,t be concerned either.
1972 Chevy c10 Cheyenne Super
#135645 10/12/2006 1:20 AM
Thanks Wrenchbender! Its now three votes saying go for it and no decenting votes. I will get it bored by my buddy. Thanks for your reassurance!
Rick In VA
#135646 10/12/2006 2:06 AM
I will add another vote, I worked @machine shop, the torque plate was an extra charge usually reserved for race engines. They are a fairly new idea, many engines have run many miles bored the old fashioned way. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#135647 10/13/2006 2:32 AM
FYI on torque plating .The reason torque plating is used is to simulate the head being bolted on.If for some reason the application has high cylinder bore distortion when the head is clamped to the block then they will torque plate hone.This assures the cylinder will be round when final honing process is completed.Your inline has a good cylinder wall thicknes so the chances of distortion are minimal.Now if you had 318 Dodge I recommend it.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#135648 10/14/2006 11:04 PM
It boggles the mind to know how high tech we were in the 40's and 50's. On old flathead fords we used a plate slightly thicker than the longer studs. It was counterbored so the head nuts would screw down on the studs lower than the top surface. This gave a flat surface for the boring bar without having to pull out 42 or 48 of those #^*$@ studs that always had a few twist off.
Evan
