8 members (carbking, 3B, msmall, Bill Hanlon, FrankenChevy, walter74, Stovebolt48, Shardean),
58
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 77 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 77 | Hello all,
Does anybody know for certain which cab marker lights fit the contour of the 60-66 cab? There are so many different ones out there that look similar, and I'm not going to drill into my roof until I'm absolutely certain I have the right lights! As always, your expertise and help is greatly appreciated.
GW
"The duty of a patriot is to protect his country from its government." - Thomas Paine
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Could you take a piece of cardboard and cut a piece to fit the contour of the roof then match it up with the marker lite . | | | | | Joined: Oct 2012 Posts: 77 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 77 | There's got to be many of our trucks that have them installed. I was hoping some who has them would just look at them and then tell me, because the model numbers are stamped on the outside.
GW
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Yankee 77's is what the factory used back then mostly on Mid and Heavy Models.
I put a set on my '64 C-30 back in the 80's.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Greenman Wood, I sent you a private message Kent | | | | | Joined: Oct 2012 Posts: 77 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 77 | This group is the best. Stay safe and healthy everyone!
Kent, I just sent a reply to your message.
GW
