5 members (rfs56trk, Otto Skorzeny, FAST55, 216wny, Gdads51), 86 guests, and 1 robot.
Topics128,038
Posts1,055,585
#1353852 04/07/2020 12:27 PM
Hello all,
Does anybody know for certain which cab marker lights fit the contour of the 60-66 cab? There are so many different ones out there that look similar, and I'm not going to drill into my roof until I'm absolutely certain I have the right lights! As always, your expertise and help is greatly appreciated.
GW
"The duty of a patriot is to protect his country from its government." - Thomas Paine
Could you take a piece of cardboard and cut a piece to fit the contour of the roof then match it up with the marker lite .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
There's got to be many of our trucks that have them installed. I was hoping some who has them would just look at them and then tell me, because the model numbers are stamped on the outside.
GW
Yankee 77's is what the factory used back then mostly on Mid and Heavy Models.
I put a set on my '64 C-30 back in the 80's.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Greenman Wood, I sent you a private message
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
This group is the best. Stay safe and healthy everyone!
Kent, I just sent a reply to your message.
GW
