| | | Forums66 Topics128,157 Posts1,056,892 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 2 Moderated | | Moderated Joined: Apr 2020 Posts: 2 | Hello everyone. Trying to get my 1952 Chevy deluxe styleline roadworthy while keeping the 216 engine intact. Needless to say I bought a new radiator that was v8 ready and didn't realize the radiator neck would be 1.5". So trying to save money by not having to buy a 235 engine thermostat housing.
My question is can you use a 1.5" radiator hose with the 216 thermostat housing? I know its 1 1/4" diameter just never tried a that big of a gap before. Worst case I could try and find a local with a 235 engine that I could buy the thermostat housing from. I'm from Towanda, KS. | | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | You could get a rad hose that is 1 1/4 on one end and 1 1/2 on the other end if that is the size difference | | | | | Joined: Jan 2013 Posts: 2,236 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,236 | We stretched mine over the difference! | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Hiya Mulky, welcome to Stovebolt.com This site is for pre-1973 Chevy/GMC trucks. As long as you keep your posts here about the mechanical bits of the drive train that interchange with the trucks, you are fine. If you are looking for parts, you can check out The Swap Meet section of Stovebolt.com to look at Parts for Sale or place an ad in Truck Parts Wanted. If you need more help with the car specific Chevrolet stuff, we recommend: https://www.chevytalk.orghttps://vccachat.orghttp://www.aaca.orghttps://inlinersinternational.orgThanks! -Woogeroo | | | | | Joined: Oct 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 26 | You can get a 1.5" hose and use a reducer at the thermostat end. Gates 26390 goes from 1.5 to 1.25, it slips inside the 1.5" hose. I've used one in the past, it has a lip to keep it from going in too far.
Jim
1935 QD 1.5 ton stake bed 1937 SD 1.5 ton stake bed 1944 MS 1.5 ton stake bed 1946 PW 2 ton stake bed
| | | | | Joined: Apr 2020 Posts: 2 Moderated | | Moderated Joined: Apr 2020 Posts: 2 | Thank you for the quick response, I'll look for both the reducer and 1 1/2" curved 90 hose. Hope to have it running by tomorrow! Thanks again! | | |
