| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Hello all Question about vibration Have a 235 with an SM420 When driving in third at cruising speed, I notice a vibration that can be felt in the gas pedal The puzzling part is it doesn’t do this all the time When it starts “acting up”, if I find the spot that is vibrating, if I let off the gas a bit it stops; if I give it more gas past that spot, sometimes it will go away. Once again, this does not happen all the time
It has a rebuilt tranny, new clutch and surfaced pressure plate
Could this be a harmonic balancer issue?
Thanks in advance | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Vibration as opposed to tires/alignment/steering wheel shake? Ujoints? I gotta think about only feeling it in the gas pedal??? That would be motor hesitation/missing/bogging/timing/fuel pump and all that. Do some tests when it does it. Push clutch in. Slip in neutral. Then rev up and down. Anyway, if it does it with clutch in or in neutral, it's rolling drive train parts. You can even get it vibrating and shut motor off. I wouldn't suggest all this stuff if I could feel it, but I can't. There are all kinds of what someone may call "vibrations". Happening in third at cruise sounds like timing/vacuum advance. Fuel or electrical. Third is 1:1 ratio and acceleration is a strain. That is my best shot at it right now. Not much help.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | It may be a motor or transmission mount issue. Is it related to torque on the drivetrain such as, does it occur more often when pulling a hill in third, or when first shifting from second to third? Vibrations can be heard in places that actually have nothing to do with the component. Is the throttle shaft/bushing functioning properly? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The rubber mounts that support the clutch housing attachment to the frame are frequently the cause of odd vibrations.
Ed
| | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Harmonic dampers are so close to the center of rotation, they seldom cause problems unless they come apart. Then its usually just terrible noise.. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Check all three motor mounts. Also check the mount at the torque tube ball. All of them deteriorate from being immerse in oil. New motor mounts would be a good idea even if they aren't totally trashed. The front motor mount rubber will squeeze down until you have metal to metal contact of the bizarre multiple pieces of metal contraption of which it is. Someone needs to come up with a better, much simple design. Where's HRL when you need him. Probably working on the next motor sickle to crash, or a 900 pound car with a 500 hp, 7,000 RPM motor in it. Carl
