1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#1355766 04/17/2020 8:27 PM
I just bought a vacuum gauge to fine tune my 54 235 with a Rochester B. What is the best place to hook to? I have a port on the carb that's plugged (I think it was a BC in a previous life) or I can connect to the manifold. My understanding is when tuning this way you need to leave the vacuum advance hooked up. Thanks for your patience and help. John
Vacuum gauge needs to be connected to a non-restricted vacuum port. Typically at the bottom flange of the carb, or on the manifold itself. Where vacuum wipers would hook up would be a non-restricted port.
Thanks, that's what I thought. One of those times I started to overthink the problem, seems I do a lot of that anymore. John
I just bought a new vacuum gauge off FleaBay to adjust my new Carter carb with. I hooked it directly to the nipple on the manifold after I pulled off the wiper hose. Worked like a charm.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Hook it up to Manifold NOT carburetor.
Carburetor is not supposed to have vaccum at Idle...
1950 Chevy 3100
