10 members (jupitor, treegrower, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B),
216
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I just bought a vacuum gauge to fine tune my 54 235 with a Rochester B. What is the best place to hook to? I have a port on the carb that's plugged (I think it was a BC in a previous life) or I can connect to the manifold. My understanding is when tuning this way you need to leave the vacuum advance hooked up. Thanks for your patience and help. John | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Vacuum gauge needs to be connected to a non-restricted vacuum port. Typically at the bottom flange of the carb, or on the manifold itself. Where vacuum wipers would hook up would be a non-restricted port.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks, that's what I thought. One of those times I started to overthink the problem, seems I do a lot of that anymore. John | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I just bought a new vacuum gauge off FleaBay to adjust my new Carter carb with. I hooked it directly to the nipple on the manifold after I pulled off the wiper hose. Worked like a charm.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Hook it up to Manifold NOT carburetor. Carburetor is not supposed to have vaccum at Idle...
1950 Chevy 3100
