4 members (Shaffer's1950, Gray_Ghost, bucktruck, walter74), 84 guests, and 4 robots.
Topics128,129
Posts1,056,700
Members48,454
Moderated
Moderated
Hello everyone. Trying to get my 1952 Chevy deluxe styleline roadworthy while keeping the 216 engine intact. Needless to say I bought a new radiator that was v8 ready and didn't realize the radiator neck would be 1.5". So trying to save money by not having to buy a 235 engine thermostat housing.
My question is can you use a 1.5" radiator hose with the 216 thermostat housing? I know its 1 1/4" diameter just never tried a that big of a gap before. Worst case I could try and find a local with a 235 engine that I could buy the thermostat housing from. I'm from Towanda, KS.
You could get a rad hose that is 1 1/4 on one end and 1 1/2 on the other end if that is the size difference
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
We stretched mine over the difference!
Socket Breaker
Socket Breaker
Hiya Mulky,
welcome to Stovebolt.com
This site is for pre-1973 Chevy/GMC trucks.
As long as you keep your posts here about the mechanical bits of the drive train that interchange with the trucks, you are fine.
If you are looking for parts, you can check out The Swap Meet section of Stovebolt.com to look at Parts for Sale or place an ad in Truck Parts Wanted.
If you need more help with the car specific Chevrolet stuff, we recommend:
https://www.chevytalk.org
https://vccachat.org
http://www.aaca.org
https://inlinersinternational.org
Thanks!
-Woogeroo
You can get a 1.5" hose and use a reducer at the thermostat end. Gates 26390 goes from 1.5 to 1.25, it slips inside the 1.5" hose. I've used one in the past, it has a lip to keep it from going in too far.
Jim
1935 QD 1.5 ton stake bed
1937 SD 1.5 ton stake bed
1944 MS 1.5 ton stake bed
1946 PW 2 ton stake bed
Moderated
Moderated
Thank you for the quick response, I'll look for both the reducer and 1 1/2" curved 90 hose. Hope to have it running by tomorrow! Thanks again!
