3 members (Chip O, Charles in CA, 1 invisible), 159 guests, and 2 robots.
Topics128,087
Posts1,055,998
Members48,430
#1355495 04/16/2020 12:40 PM
Are the fenders the same between all of the AD trucks or are the big bolt trucks wider in the nose?
Front sheet metal above 1-ton 3800 Series is bigger. 1/2 ton through 1-ton are the same.
I believe the wheel openings are also a bit larger on the 1 ton and larger trucks. I have not verified that myself though.
2 Offline
the 1 ton is the same as the 1/2 ton, the wheel is just closer to hitting metal smile
-s
Crusing in the Passing Lane
GMC made some full width front fenders for trucks with 20" wheels, I have 2 sets.
Ed
I believe there are at least three different GMC front fenders. I have a 49 with fenders wider than a pickup, and a 53 tandem with fenders that are wider yet.
