10 members (TexasJim50, Jay R, TUTS 59, Hotrod Lincoln, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, 1 invisible), 89 guests, and 2 robots.
Topics128,134
Posts1,056,411
Members48,441
#1355432 04/15/2020 11:02 PM
Hello Stovebolters,
Today I began filling the un-used holes in the firewall of my 1937 GMC. There are several holes that I am unsure of originality or purpose. Any help would be appreciated.
Here is a picture of my firewall. https://photos.app.goo.gl/wJ4yx6C5ZkPFAYvu6
In the photo I have numbered the holes and below I've listed is what I think the hole is for. If anyone has information on this firewall please let me know.
Hole #1 is for GMC only hood props.
Hole #2 and 2a I think are added by prior owner. Maybe for a voltage regulator and wiring harness?
Hole #3 is for vacuum line to wipers?
Hole #4, and 5 unknown.
Hole #6 is for coil wire.
Holes 6a are original and unknown purpose.
Hole #7 is for the Canadian VIN plate
Holes #8 original but unknown use.
Hole #9 Original. Is this for wiring from starter to Amp gauge and on to electrical system?
Hole #10 Looks original but no idea what it could be for.
Please let me know what these holes are for.
Also does anyone know where the original voltage regulator mounted? How is the wiring harness for the headlights and generator routed from the cab to the engine compartment?
Thanks for your help,
David
Crusing in the Passing Lane
There should be one for choke cable and hand throttle cable.
Ed
Choke and hand throttle goes through the middle rubber grommet with 3 holes along with shield cable to the coil. I going what is on my 37 chev. Also if there was a heater that would have been the 2 3/4" holes on passenger side that look like they have been filled in.
1937 GC
I will take a crack at this, however, be forewarned this is based on my '37 Chevy.
Ed, the choke, hand throttle, oil pressure line and water temp line go through the oblong grommet in the center which is held by the metal bracket.
Hole #1: I don't have these--it is not a GMC
Hole#2: One of the small ones is for a harness clip, placed inside. The others don't belong. Maybe you can tell which is original.
Hole#3: Yes, vacuum line to wipers.
Hole#4: I don't have that one at all.
Hole#5: For another harness clip, placed inside.
Hole#6: For the armored coil wire (Elektrolok). The smaller holes (6a) don't belong.
Hole#7: I don't have these.
Hole#8: I do have this, looks original, I don't know what it is for.
Hole#9: Yes.
Hole#10: I think that hole should be threaded and is one of the holes for the floorpan to be bolted to.
My truck did not have a voltage regulator, just a voltage cutout, which is mounted to the generator. The harness itself exits the cab forward to the horn and lights between the floor board where there is a sort of a cutout, and the cab just below your hole #5, and to the left in the picture from the driver side hood latch. If you look at your floorboard you will see what I mean.
The above observations are based on what little was left of the wiring on my truck, and examining another complete '37 Chevy. I hope this helps.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Great info. Thanks to all for the replies. I found a good picture on the net. https://photos.app.goo.gl/63XLCJkeAq1AcuG68
I agree with what Kent said except, I think both holes marked 6a are original as I see them on other vehicles. https://photos.app.goo.gl/1fRyZzMm4rxs2mNC8
My guess is the lower 6a and the hole #8 are for clips to secure the wire from starter to amp gauge. The upper 6a hole is still a mystery (to me).
Also, I don't think hole #10 is for the toe board/floor pan. The floor pan screws into a center cage nut but that's not hole #10. Hole #10 doesn't correspond to any hole on the floor pan so that one remains a mystery. Here's a better photo with a green arrow pointing to where the center cage nut is missing: https://photos.app.goo.gl/9rU1KRv4uouJt7Cv9
Thanks for the help. I ordered some cage nuts and in 12 hours holes #2 and #4 will be filled!
David
The center oval grommet has the Choke, Throttle, Oil and Temp going through it...no electric. The oversize hole in the oval trim ring gets the Temp line so the bulb passes through.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
David,
I went back to look at my truck. Regarding hole #10, you are correct. That does not correspond to where a cage nut is placed. I do not have that hole either and there is nothing I am aware that requires that hole. I recommend you fill that hole in 12 1/2 hours!
Regarding holes #8 and lower #6a you are correct again. In fact, I have a clip for the wire in lower #6. Upper #6 is present in my truck also, but nothing in it. I probably should put a clip in #8, the wire is right there (on the inside, of course).
This has helped me, thanks.
Regards,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
