8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck), 87 guests, and 2 robots.
Topics128,202
Posts1,057,409
Members48,471
Hello Bigbolters! Jeff here from NW Arkansas. I just picked up a late 30's to mid/lateish 40's 1.5 ton Chevy truck. I have plans of tearing it down and putting either a 4BT or 6BT in it and leaving the rest of it stockish. I know it's a big, multi-year project but I feel like I'm up for the task. I just finished building a '66 Chevelle and wanted to build a truck next. I wasn't really looking for 1.5 ton but fell in love with them after looking around for a truck to build. The truck did not come with a title so I have no idea what exact year the truck is. I've looked through a lot of posts on here but am not able to figure anything out as to when the truck was built. Any help you guys could throw my was as to what to look for to identify the exact year would be greatly appreciated. Here's what I know about the truck. It lived most of its life on a wrecking yard near Cottonwood Falls, Kansas. It was a wrecker that was later converted to a water well truck, for pulling well pipe, I assume. The man that owned it was JC McKnee. That's literally all I know about the truck. It's got some dings and some rust spots on it that I think just add to the character of the truck. I'll probably at least pound out what I can and pop a weld over the rust holes to keep the rain out but like I said, I want to leave it mostly stock...except for the Cummins that is. Look forward to digging into the truck after my shop is built (4 weeks) and hopefully will get to know a few of you. I've attached a pic of the truck. Thanks!
Big Bolt Forum Moderator
welcome to the site! That looks like a sweet truck! are you working on getting a title for it? I would not do much till you get that part straightened out!
Mike
Welcome!
Your truck is a '41-'46. Others may be able to narrow it down a little more for you.
Good luck, and, as been mentioned, get your title straightened out before digging too deep into it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Look under the hood on the passenger side of the cowl for a data plate. If you can read the number, that will tell you the year. Looks like a '41-'46 per the grille.
1 Offline
That is one super cool looking truck. Keeping the gin poles?
Go to the Tech Tips. Look under "Identifying your truck".
This should answer a lot of your questions.
Harold
Harold
Moderator
Moderator
2 Offline
Welcome to the garage!
I agree that it is a 41 or 46 truck.
Almost all vehicles in those years went straight for the war effort.
Here is our 46.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I just started digging into how to get a title for it. Looks to be quite difficult. frown
Thanks, Kevin. I'll take a look next time i'm out where the truck is. I've got it parked on some property I plan to build a house on.
Absolutely...that's honestly why I bought the truck. I wanted the old wrecker look. They're a bit long for a wrecker (see attached picture) but I'll be able to shorten them to make it look like a wrecker again. It's also got a Tulsa winch on the back. The truck was rougher than what I was looking for but the wrecker bed sold me!
Here is our 46.
Don
Love the truck, Don!
Crusing in the Passing Lane
They even made some of that body style in '47, using up parts. A 4bt will be a tight fit, especially with an I'cooler. A 6bt will not fit without extensive mods. That might change the look of the truck.
Ed
Ed
I haven't done any measurements or research on a 4BT vs. 6BT so it's TBD. I did see a guy who put a 6BT in a 1/2 ton early 40's truck. He had to move the radiator fwd a little bit but no firewall mods were needed.
Where is the door lock on the passenger side? If in the door 42 -46. If in the door handle 41. Look at the rear window, if it has a pot metal bolted together surround it is 41, if only a rubber surround 42-46. The park lights look to be after market, that does not help I'd. It. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Here is our 46.
Don,
Didn't realize you had a '46 also. I like it!!
Rich
1947 Loadmaster
Door lock is in the door on the passenger's side and the rear window has rubber around it. So that narrows it down to 42-46.
