5 members (rfs56trk, WingWright, Jon G, Rusted Nut, Woodcmiami), 117 guests, and 1 robot.
Topics128,109
Posts1,056,260
Members48,439
#135510 09/26/2006 8:50 PM
Junior Member
Junior Member
I am running a 55 270 CI in my 50 GMC 100. Motor is rebuilt, bored, shaved head, howard 240 cam, aluminum intake w/manafold heat, holly 390 cfm w/vacume secondaries, cast iron fenton headers, smithy mufflers, and a s-10 style HEI.
I converted the column shift to the old truck 4 speed floor style, kept the enclosed drivshaft, and updated the rear with patricks 3:55s.
The tranny is probably the biggest set back in the system. Maybe a T-5 down the road will help.
I usually shift around 3,000 and often up to 3,500 RPM. It was recomemended that I set 5000 as my red line. The other night I got to 6000 RPM in a hurry. Don't notice any problems, yet.
I get beleiveable performance up to 3,000 RPM. Once I pass that, the truck just keeps taking the throttle and doesn't slow down fo nothin'!
Just wondering what you guys are experiencing with similar set ups?
Grant in Albuquerque
Sweet!
Did I see that correct? 6000 RPM eek eek
I'm hoping my 302 Jimmy will drop my jaw too! Congrats! grin grin
Sounds great. I plan to put a 4bbl on my '54. How is yours oriented?
Mine runs great, but its still stock and I've never turned it nearly that fast...
Junior Member
Junior Member
The carb sits with the primaries towards the head, secondaries outboard towards the left fender.
The drive gear, in the 4 spd, for the speedo is shot. So much for the transmission guy telling me it was "all OK as far as I can tell." So, I use the tach for a speedo. OK when steady throttle but not very accurate when accelerating.
