2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1354661 04/11/2020 11:38 PM
I'm working on the 270 out of my GMC 350 and I noticed the ears where the bolts attach the generator to the engine are both snapped off. I happen to have a 55 Cadillac engine,V8, in the garage. It has an intact generator. Can I use it on my 270 ? thanks in advance
hotshoe99 #1354665 04/11/2020 11:58 PM
Crusing in the Passing Lane
Electricity knows no brands, if it fits, use it.
Ed
hotshoe99 #1354674 04/12/2020 12:40 AM
H Online: Content
Be sure to swap the regulator from the Cadillac as well. The Caddy will probably have a higher-amperage generator than the GMC, which is a good thing, but in order to make use of the higher capacity, the corresponding regulator must be used, or your original regulator would have to be reset to the higher amp rating. The Cadillac generator will probably have ball bearings front and rear and it will probably be longer from end to end, so some tinkering with the GMC bracket might be necessary. I usually use a short section of 1/4" pipe as a spacer, with a longer bolt on one end.
Someone who is skilled with a TIG welder can fix those broken end frames, so don't discard them.
yes I noticed today the caddy gen.is longer. Don't have the regulator from the caddy so I'll see about getting one of those.
hotshoe99 #1354900 04/13/2020 12:25 AM
H Online: Content
OK- - - -I just looked up some specifications. 54-56 Cadillacs ran a 30 amp generator, which is probably the same as the GMC ran. Your regulator will most likely work without doing any swapping. Be sure to polarize the generator by momentarily touching a jumper wire from the BAT terminal on the regulator to the ARM terminal. (about 1 second is plenty) That's particularly important if the GMC is running a positive ground electrical system. The generator will work on either polarity as long as it's polarized after installation.
Thanks for the info !
It was a little windy today but I got the engine all painted today.
I'm going to sand blast the manifold tomorrow and see about making the caddy gen fit.
hotshoe99 #1355444 04/16/2020 12:44 AM
After you have followed Hotrod's advice above and you have it running, you will likely need to adjust the regulator for voltage. At least check to make sure it is properly charging and not just brightening the lights. Perhaps you know this already.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
If you have the manifold(s) off for sandblasting, make sure if you separate them, you only loosely connect them together until you tighten the nuts(brass I hope) holding them to the head, then you can tighten them together.
Ed
